Cannot make scale logarithmic for curve import wizard in Thermal Package Description
Error message appears when I try to change scale from Linear → Logarithmic. It says all values of X (or Y) must be positive (even though the values of X/Ymin and X/Ymax are already positive). Is this a bug?
So how do I change the scale to logarithmic?
Running Standalone on Windows 11.
Tried on version 4.9.4, version 4.8.9 and version 4.7.5.
Am I missing something?
The error message refers to the data points rather than the axis limits. Very likely your table contains the default data point [0, 0].
The wording of the error message was changed in PLECS 4.9 to make this clearer:
Logarithmic scale requires that all data points in the table have positive X values.
hi @wolfgang, thank you for the answer. Yes that solved it.
