How to achieve a variable frequency AC voltage source
You can use a Trigonometric Function and a Voltage Source (Controlled) component to create a voltage source of arbitrary phase and frequency.
For the time/angle input, you can use a Clock component for offline simulations and for real-time simulations you’ll want to use a wrapping integrator. There is an example of a C-Script based wrapping integrator in the C-Script documentation in the PLECS Manual (see: Event Handling - Wrapping Integrator) and variations in several of the demo models (Look in the PLL’s of the STATCOM Cascaded H-Bridge Converter, Three-Phase Grid-Connected PV Inverter, and Z-Source Inverter, among others).
