How to calculate the magnetic Resistance of a coil in the magnetic domain?
is there a way to calculate the magnetic resistance of a coil with a magnetic core without knowing the core losses?
The main losses are: Hysteresis losses and eddy-current losses.
How do I condense them in one singel magnetic resistance in the permeance-capacitance analogy used in the Plecs Magnetic Domain, just using the datasheet of the core material? (see Attachment)
The Paper linked in: https://forum.plexim.com/845/calculate-magnetic-resistance-transformer-simulation-magnetic dosen’t help me very much because they don’t use a magnetic resistance to simulate the losses.
Thanks.
pdf-n95.pdf (662 KB)
Hi, one option would be that you make use of the curves in “relative core loss” and fit a first order term (a resistor in parallel with a inductor).
