Tim, I’m sure you will have moved on from this problem now, but I’ll post my solution in case someone else finds it useful…
I had a similar problem modelling a current and power limited capacitor charging power supply. In the end I replaced the voltage source with a current source controlled by the capacitor voltage. See model attached.
Jonny
Charging Power Supply example.plecs (12.6 KB)
