Hi everyone,
I am encountering an issue where my oscilloscope fails to display the step signal correctly in my RT-BOX real-time simulation. The assigned I/O pin is correctly configured, and the corresponding RT-BOX status LED is lit up. Notably, the same simulation model and identical oscilloscope setup worked properly during my previous test, but the step signal cannot be captured this time.
I have double-checked the oscilloscope configurations, physical pin wiring, RT-BOX runtime status, step signal source parameters, and comparator settings. All these settings are listed below for your reference.
Could anyone advise what might be causing this problem and what troubleshooting steps I should try? Thank you very much for your help!
