Complex numbers in PLECS C-script
Hi
I tried to write a complex number in C-script.
#include
float j;
j = csqrt(-1);
It’s a code on the top for complex numbers.
what’s problem ?
PLECS C-Scripts support complex numbers. The issue is that you must define your variable as a complex number in your code declarations. For example “float complex a;”.
Attached is an example highlighting complex number usage in C-Scripts. Note if a complex number is directly used as an output signal only the real component is used. This is shown in the example.
complexScript.plecs (7.99 KB)
