I am trying to define many inputs (voltages in a multilevel converter) as a matrix and not one by one. Could anyone help me?
Thank you ![]()
Thank you ![]()
See the excerpt from the C-Script help below.
Say you have a 3x3 matrix. If Iām understanding your question correctly, one could:
Set the Number of Inputs field be ā9ā. There will be one input port to the C-Script block. Access the matrix entries as InputSignal(0, 3*Row + Column)Set the Number of Inputs field be ā[3, 3, 3]ā. The C-Script will have 3 input ports, each with three elements. Access the matrix entries as InputSignal(Row,Column)
