Fortescue Transformation
Hello!
In which way can I implement the Fortescue transformation?
I know that Plecs doesn’t support the complex number.
Thank you
You will have to expand the matrix multiplication on a row-by-row basis. This can be implemented via Function blocks or, for more complex computations, in a C-Script block. Please take a look at how the Transformation blocks are implemented in the PLECS Control library (Subsystem -> Look under mask).
Yes, I know. And for example in the following row [1 a^(2) a] with a=exp^(-j2pi/3), what I should write in the Function block?
u(1)+u(2)exp^(i2pi/3)+u(3)exp^(-i2pi/3)? Does it support the complex number i?
It would be helpful if you could provide a bit more context. What are you trying to do with the transformation? I.e. generate or analyze a signal? Can you provide a block diagram?
