Sorry for the off-topic answer!
The documentation in section “Simulation Scripts” states:
[…] The scopePath is the path to the scope within the model including the model name, e.g. ‘DTC/Mechanical’. To access Bode plots from the analysis tools, use the model name followed by ‘/Analyses/’ followed by the name of the analysis, e.g. ‘BuckOpenLoop/Analyses/Control to Output TF (AC Sweep)’. A leading dot (.) in the scope path is substituted with the current component or model as described in “Path Substitution” below. […]
Here you go.
Cheers
Falk
