How can I simulate repeating sequence block in plecs?
Hi
I am simulating irradiation input signal and I need a block such as “repeating sequencing block” in Matlab.
how can I simulate input like attached?
Unfortunately, you did not attach a file. PLECS does not have such a library component, but this logic can be developed from primitive blocks in the same way as in Simulink- see the attached example built in PLECS Standalone. To open the model in PLECS Blockset, add an empty PLECS Circuit block in a Simulink model and from the File menu, choose “Import from Standalone”. You are able to look under the mask of the component as well as modify the mask parameters and initialization commands.
repeating_sequence_example.plecs (8 KB)
