I am running a MATLAB simulation with PLECS Blockset. In my PLECS Blockset, there is a grid model embedded inside a subsystem. Using Signal inport and signal outport, i am feeding in and taking the signals from the system. I am getting this unusual error which doesn’t point to any port or terminal. I have attached the screenshots and simulation model to this question. Your response awaited.
This is indeed a bug. The developers suggested the following workaround–
“To fix the Circuit block, you need to copy the complete schematic into a fresh Circuit block (and then you need to also copy all simulation parameters).”
