Matlab code to plecs
Hi
I am working on the MPPT algorithm (P&O) and I did it in MATLAB function and it works. However, I cannot transfer it to C-script, and I dunno how it works in plecs.
could anyone help, the script is as follows:
function duty = MPPT_algorithm (vpv,ipv,delta)
duty_init=0.1; duty_min=0; duty_max=0.85;
persistent Vold Pold duty_old;
if isempty(Vold)
Vold=0; Pold=0; duty_old= duty_init;
end
P=vpv*ipv;
dV=vpv-Vold;
dP=P-Pold;
if dP~=0 && vpv>30
if dP< 0
if dV < 0
duty = duty_old - delta;
else
duty=duty_old + delta;
end
else
if dV<0
duty =duty_old + delta;
else
duty = duty_old - delta ;
end
end
else
duty = duty_old;
end
if duty>= duty_max
duty=duty_max;
elseif duty
There are several examples of C-Script-based MPPT algorithms in the PLECS demo model library already. See the “Single-Phase PV Inverter with Partial Shading” model, for example.
