Attached are the waveforms of the output signal from one of the C-script blocks. Prior to using the ADC block from the TI C2000 Target library to capture the inputs for the C-script block, I did not encounter a discontinuous output as shown in the file attached. Previously the inputs to the C-script block were captured using Analog-in blocks.
Is there a way to resolve this issue ? Since the discontinued output from the C-script block resulted in unwanted behavior on the power-stage of the system.
Thank you so much.
Ricky
scope_PLECSforum.pdf (126 KB)
