I am looking to set up a Permanent-Magnet Synchronous Machine model similar to the Demo, however I want to replace the 2 level IGBT converter block with an inverter of my own design. The ‘pulses’ input for the converter block explains the gate input is a vector of three signals, with the upper IGBT in a leg being turned on by the positive and the bottom IGBT turned on using the negative signal.
In practice when I try to use these signals in an inverter design similar to the three phase voltage source inverter Demo which requires individual signals for all 6 devices I am having issues. If I simply multiply the signal by -1 to get the negative signal for the bottom device in the leg I get the errors:
"Inconsistent source conditions after switching.- short-circuited voltage source permanent_magnet_synchronous_machine/Circuit/V_dc "
and a Voltage-Current impulse error
I have tried adding dead time to the signals but the errors remain and zero-crossings become a problem
Any help would be greatly appreciated, I was hoping this is quite a standard procedure to drop in a more complex inverter into the pmsm control circuitry
