Hi everyone.
In Matlab/Simulink it’s possible to write a code in a block called Matlab Function so you can manage your inputs and creates the desired outputs.
Well. First question: Is there in Plecs Standalone the similar “block” ? Is the C-Script block ?
Second question: Is this the only way to get my goal?
Thank you.
Bye.
Yes, in PLECS Standalone, the C-Script block is likely your best option. It might also be achievable using the State Machine block. Have you tried either of these?
Best,
Hi!
Thank you for your answer.
I tried to use C-Script but for some things is quite difficult… maybe because I don’t know very well C!
I’ll take a look at State Machine block… I didn’t know it existed!
Regards.
