I want to Transpose sine-wave data in c-script, the sine-wave equation is:
X = 200sin(2pi50t), where t, is Time already defined, usually in matlab used this character ( ’ ) to transpose vector or array. So is that possible to do in plecs c-script
Did you consider loading the matrix data in an initialization script, and transposing the time vector there, prior to being passed to the C-Script block as a Parameter?
1D C arrays or vectors do not need to be transposed as there is not a distinction between a [1xN] or [Nx1] like in MATLAB/Octave.
If you have a higher order matrix, then you can use for loops and re-indexing. There are plenty of code examples available elsewhere for this.
Note that oftentimes in PLECS C-Scripts, one would not use an array of time values, but rather the CurrentTime macro, which reports the simulation time as a single C double.
once I implement the x equation in matlab, the data inside x is (1 x 2000) by using this character (') the data will become (2000 x 1), I want to do the same in plecs c-script
I want to transpose the sinewave signal which is the input of C-Script block as shown in the attach model, for more information you can look into matlab code.
