About how to use PIL
hello
When trying to use PIL, I looked at the demo documents of FOC and NPC, and needed to download a. Ehx file first, then configure PIL, and finally modify the C file to re-down to DSP.Is this.ehx file common to all simulations, or is it a FOC and NPC demo?If I want to create a new model, how do I get this.ehx file?Is this EHX file used to initialize DSP communication to communicate with PLECS?
In addition, the demo document mentioned that “PIL Prep Tool” software was used to generate some required C files. However, there was no function in the generated file after I clicked on it, and only "WARNING!All changes made in this File will be lost!"So how does this software work?
There are too few official documents on the usage of PIL, and we have no idea how each step should be carried out, how to communicate with DSP, and how to modify The C code.Do you have relevant instructions for use?
Contact: +86 18004767455
WeChat: 18004767455
thank you
The “*.ehx” files provided with the PIL demos are of the “extended hex” format used by the documentation website.
I recommend that you work with the demos provided and review the documentation in conjunction with the sample code.
Also, feel free to contact our support team via email if you have specific questions or need help with converting your project for PIL.
Thanks for your reply,
I modified the buildsteps in the CCS project as per the document you gave me, but at compile time, the pil_symbols_c.inc and PIL_symbols_c.inc generated displayed the following: the correct probe code should not have been generated.What is the reason?
error Error during parsing of ‘calib.pilpp’: syntax error in line 176 before ‘_Pragma’
error Error during parsing of ‘control.pilpp’: syntax error in line 176 before ‘_Pragma’
error Error during parsing of ‘main.pilpp’: syntax error in line 157 before ‘_Pragma’
error Error during parsing of ‘pil_ctrl.pilpp’: syntax error in line 157 before ‘_Pragma’
error Error during parsing of ‘pu.pilpp’: syntax error in line 228 before ‘_Pragma’
error Error during parsing of ‘ain_2837x.pilpp’: syntax error in line 203 before ‘_Pragma’
error Error during parsing of ‘canbus_2837x.pilpp’: syntax error in line 176 before ‘_Pragma’
error Error during parsing of ‘dio_2837x.pilpp’: syntax error in line 215 before ‘_Pragma’
error Error during parsing of ‘dispatcher_2837x.pilpp’: syntax error in line 181 before ‘_Pragma’
error Error during parsing of ‘gatedriver_rtbox.pilpp’: syntax error in line 176 before ‘_Pragma’
error Error during parsing of ‘hal_2837x.pilpp’: syntax error in line 177 before ‘_Pragma’
error Error during parsing of ‘power.pilpp’: syntax error in line 176 before ‘_Pragma’
error Error during parsing of ‘pwm_2837x.pilpp’: syntax error in line 268 before ‘_Pragma’
error Error during parsing of ‘qep_2837x.pilpp’: syntax error in line 179 before ‘_Pragma’
error Error during parsing of ‘sci_2837x.pilpp’: syntax error in line 176 before ‘_Pragma’
error Error during parsing of ‘spi_2837x.pilpp’: syntax error in line 176 before ‘_Pragma’
error Error during parsing of ‘F2837xS_Adc.pilpp’: syntax error in line 127 before ‘_Pragma’
error Error during parsing of ‘F2837xS_DefaultISR.pilpp’: syntax error in line 130 before ‘_Pragma’
error Error during parsing of ‘F2837xS_DevInit.pilpp’: syntax error in line 117 before ‘_Pragma’
error Error during parsing of ‘F2837xS_GlobalVariableDefs.pilpp’: syntax error in line 130 before ‘_Pragma’
error Error during parsing of ‘F2837xS_Gpio.pilpp’: syntax error in line 129 before ‘_Pragma’
error Error during parsing of ‘can.pilpp’: syntax error in line 183 before ‘_Pragma’
error Error during parsing of ‘interrupt.pilpp’: syntax error in line 177 before ‘_Pragma’
