Hi
I am modeling an estimator, where the angle should get reset, once a certain condition (minimum speed) is satisfied.
On the transition arrow dialog box in the state-machine block there are 3 things that a user can specify
Trigger (works)
Condition (Seem redundant, because an && in the trigger condition would achieve the same thing)
Action (No example of how this is to be used)
Could someone tell me how to create a 1 time reset on a transition ?
Thanks
Srinath
Hi Srinath,
To achieve what you’re attempting, I believe the state-machine example provided in the demo model titled “Buck Converter with Constant On-Time Control”, could be modified. I created a simple model for you. Please find it attached.
An explanation for “Trigger”, “Condition” and “Action” is provided in the tutorial here – https://www.plexim.com/sites/default/files/tutorials/finite_state_machine.pdf, on pages 4 and 5.
Regards,Manu
state_machine_example.plecs (15.3 KB)
