Change position of ports in subsystem icon
Hallo,
I would ask you, how can i change position of port (input,output) in subsystem icon in circuit.
Thank you very much
As per our documentation:
You can move terminals with the mouse around the edges of the subsystem by holding the Shift key while dragging them with the left mouse button or by using the middle mouse button.
You can also rotate the subsystem using the options in the Format menu.
Thank you, it works.
The procedure is also described here in our knowledge base: https://forum.plexim.com/t/moving-subsystem-terminal-positions/2700
