I am currently using a subsystem from my library multiple times in a model and it has many configurations. The problem is, it would take a lot of time clicking in every subsystem and change it. Is there a way to change the configuration of these subsystem all at once by defining them in the parameter?
Choose “reference” as the configuration parameter of your subsystem, then choose a variable name you like, for example “config”. Then define this variable “config” in the model initialization commands window with an integer value starting at 1 for the first configuration, as shown in the attached screenshots.
