I would like to define a variable ambient temperature in the thermal analysis of my inverter model. The ambient temperature should initially be 25°C and reach 50°C after 120 seconds.
For this purpose, I had provided a Controlled Temperature Grounded, which is fed by a ramp signal (see Figure 1). Unfortunately, the thermal simulation does not take into account a linearly increasing ambient temperature as the ramp input signal is simply ignored.
However, if I feed the Controlled Temperature Grounded with a Constant Signal Block, the given value, e.g. 25°, is taken over by the Controlled Temperature. (see Figure 2)
So what would be the basic procedure for taking into account a linearly increasing ambient temperature in a specific time window in a thermal simulation?
I look forward to your feedback!
Best regards
THK
