As per the PLECS manual I am trying to generate elf file to be called in python. I have tried using the boost converter demo model for the same.
The manual says:
Open the Coder + Coder options… window, choose the System tab. Select PLECS RT Box 1 from the Target drop down menu.Keep the Target Device field empty to only generate the .elf file without uploading it to a specific target. The .elf file is placed by default in the directory that contains the PLECS model file.I am unable to select the system tab in Coder options window. Please find the attachment and request for a help on this
You’re in the right window, but clicking on the wrong item. The System tab referred to here is better understood as a tree-like view where you can see all subsystems that support code generation. You should note that the the “Plant” and “Controller” entries in the System tab correspond to Subsystems in the main PLECS schematic, and the “boost_converter” at the top level identifies the top-level system.
Here you should select “Plant” in the left hand window just below where you circled and then click Build to generate code for the plant. Then in the directory that contains the PLECS model file, you will see “boost_converter_Codegen” which contains the Plant.elf file. If you generate code for the “Controller”, you’ll see Controller.elf in that same folder.
Thank you. I could use the elf file for connecting via python.
