I have designed a multilevel inverter. I have done thermal modelling of IGBT and diode. When the load is reduced it shows 'Cyclic behavior during switching ’ error. When the load is increased it works normal. I have set variablestepdiscreate ode23tb solver, and tightened the tolerance and diode turn on threshold.Please help me to resolve this error.
Thanks for sharing the investigations you’ve done so far. Based upon your response it sounds like you have already reviewed the general FAQ on this error message. A model would be necessary for further debugging insights.
