Debugging dll sometimes cause load symbol problem
I have a model A that has another model B as a sub-module. I have kept a DLL block inside submodule B and linked it to correct dll file. Through visual studio I want to debug while simulation. So I use attach process feature to attach it to plecs.exe with the name showing the model A. Everything usually goes well.
But sometimes I see this error:
Once this error starts popping up, no matter what I try, it never solves. I have to revert back all the changes I did in plecs and restart laptop and freshly start again it works.
So any of you have idea what happen here?
Hi Vishwesh,
Visual Studio official documentation provides guidance on this topic. There is quite a bit of other guidance regarding this error across stack overflow and other programming sites as it often relates to the build process, loading the wrong dll, caching of symbols, etc.
A few other thoughts related to PLECS integration:
  • If PLECS has crashed, use your task manager to ensure no plecs.exe instances are lingering. Windows will not unload a DLL while the process lives and VS will silently keep stale symbols. You want to ensure you’re connecting to the correct plecs.exe instance.
  • Best practice would be to attach the debugger before running the model in PLECS.
  • If the same DLL is loaded multiple times in one simulation or even multiple different simulations one needs to be cautious.
Bryan
Hi Bryan,
Thanks for your response. I followed the VS documentation and loaded the suggested symbols PDB file. However, even after selecting the correct PDB file, I still get the message: “could not load the symbol.”
For context, PLECS had crashed earlier, and I restarted it before this issue occurred. At the time of the crash, I made sure to open Task Manager and manually end the lingering plecs.exe process.
I’d like to clarify the best practice here. Do you mean the recommended sequence is:
  1. Load the model in PLECS
  2. Attach VS to the PLECS model’s executable (the one titled myModelName in my example image)
  3. Run the model simulation
Yes, that is the recommended sequence. Once PLECS crashes, the operating system and VS Code are responsible for managing the DLL resources.
After the crash have you tried:
  • Clean Solution → Rebuild (in Debug mode) ensuring that DLL is fully deleted
  • Tools → Options → Debugging → Symbols and click Empty Symbol Cache
  • Performing the above steps and restarting Visual Studio?
Of course one needs to ask - why is PLECS crashing? With a DLL block it’s typical that the crash is a result of actions within the DLL. Presumably you are using breakpoints for this purpose, but one could always default back to clunkier print debugs, and then revert back to a more typical workflow.
