DLL example error filename
I have tried to use DLL but I always have the same error message:
“Error evaluating parameter ‘Filename’ in component Modulation: Cannot load library ‘C:\Temp\visualSVM\MOD\Debug\dllMOD.dll’.”
The file “dllMOD.dll” exist and is in the same directory than my plecs file
I have already tried to compile and gebnerat DLL with visualStudio and CodeBlocks.
Any idea ?
One common source of this issue is the DLL’s target platform not matching the PLECS version. With a 64 bit PLECS executable, the DLL must be compiled for a 64 bit system.
Are you compiling for an x64 target platform?
Are you able to successfully compile a simple model from the “Using the DLL Block” tutorial?
Thanks for comment. I change the target n Visual Studio to x64 and it is now working !
