I made a 3-ph inverter PLECS model today and a DLL was used to connect my codes which were written in visual studio.
The problem is that there was a error when I wanted to use rt box in real-time simulation.
The error’s detailed description was “This component does not support code generation: Grid_Connected_Converter/DLL”, so I really wonder if the DLL can’t be used to rt box simulation.
Sincerely
The usage scenario for the RT Box is to generate C code from a model and then compile this code for the special execution environment of the RT Box. A DLL that was compiled for your Windows computer (that uses a different processor and a different operating system) cannot be used on the RT Box.
The easiest solution is to either model the behavior of your DLL with PLECS blocks or to use a C-Script (which can be compiled for both your computer and the RT Box).
