PLECS comes with SPWM. What should I do if I want to use SVPWM
Hi Wangjinyu,
We are currently working on adding SVPWM support to the RT Box library, but in the meantime, space vector modulation can be achieved by adjusting the duty cycle inputs into the PWM block.
Refer to the “Three-Phase T-Type Inverter” under PLECS Demo Models > Power Supplies for one implementation that should be reasonably efficient (see screenshot below).
We also have a C-Script based implementation (attached) that will work, but might be less efficient due to the use of trigonometric functions.
Hope this helps!
Regards,Manu
SVPWM_2L_VSIdemo.plecs (53.8 KB)
Thank you very much!
