I wonder how can I draw a draft like this one below Gain verse frequency in CLLC converters with PLECS standalone. In many papers, authors usually use this kinds of pics as comparison and I wonder how they get the data easily form PLECS. From my perspective, I have tried to pick up some points to fit the curses, but ti is not so convenient in several cases.
To plot several static operating points one will have to run a transient or steady-state analysis for each operating point.
A simulation script would be one solution. Refer to the “Buck Converter with Parameter Sweep” demo model for an example simulation scripts that can be modified for this type of analysis. Once you have the data available, then you can generate a plot using either Octave (if you are using an Octave Script for PLECS Standalone) or a Python/Matlab plotting library (if you are using the RPC interface for PLECS Standalone).
Thank you, I will have a try. Have a nice day.
