Hi everyone.
I’ll try to explain my problem.
I have a non-linear load in Simulink (modelled by differenzial equation) that it must be powered by an inverter (built into a Plecs subsystem).
Now the problem is: how can I interface the two systems? I tried to add three electrical port (one per phase) in the Plecs circuit, then I connected my load to the Plecs block. The simulation starts and I can measure the voltages but only into the Plecs circuit! Outside the Plecs block, in Simulink, I see zero voltage and current!
What is the problem? Where I’m doing wrong?
To be clear, I’ve attached two screenshot.
Thanks!
