I have designed a three phase inverter control circuit but i’m having trouble correcting the width of the input terminal on the multiplexer to match that of the output. I keep getting the error:
“Error in component Voltage Source Inverter/Demux3: Width of component terminal (3) does not match width of connection (1). The connection width is fixed by component Voltage Source Inverter/Symmetrical PWM/Configurable Subsystem/Single edge/C-Script. Check the parameters and connections of these components to correct the error.”
