I’m designing a complex system but the labels of components makes my work less neat. For example a resistor labelled “R1”. How do I completely erase the label “R1” from my design?
You can right click on the block and uncheck the “show name” option that appear under “format” when you right click. Alternatively, you can select the block and press ctrl+shift+N to hide the block name.
