I am currently conducting research on artificial intelligence and power electronics. I have trained a neural network in Python and would like to use it to control a converter, but I am unsure how to port it to PLECS.
Please see the “Buck Converter with Controls in Co-Simulation” demo model which suggests a simple but effective way to link Python and PLECS together.
Thank you, I tried running the demo, but it returned an error message “Cannot read value from input file.” I searched for a long time but still don’t kno
w where the error occurred
I tried to close the terminate function code and check if the output Python. txt file exists. The answer is yes. Python read the output PLECS. txt file normally and stored a number in it, but PLECS failed to read this file. I don’t know why.
I have resolved the issue, and it seems that the fscanf function is not working. I have modified the code for the read section. I replaced the fscanf function with fgets and atof to make the simulation run smoothly.
Finally, experts, I would like to ask if this can generate RTbox code. Thank you.
No this code will not work with the RT Box. The RT Box real-time cores will not have necessary underlying OS support for the Python interpreter. Perhaps you could develop something using the communication (e.g. UDP, CAN) or automation blocks (Programmable Value / Data Capture) but I suspect the latency will be unacceptable for most real-time control / modeling needs.
By the way, thank you for pointing out this error and implementing your own fix. We’ll address this in an upcoming release so the example works better out of the box!
I also stumbled upon non-functional fscanf() and finally found this forum discussion. As far as I’m aware of, the co-simulation project is the only demo that uses fscanf() in C-scripts, thus the issue probably didn’t become obvious before V4.7. I wonder however how the demo has been verified, does the problem only show under Windows OS? Or are there other preconditions?
I noticed that the bug apparently isn’t fixed in most recent V4.9.2. Can you give a schedule? I also wonder if other fstream functions are affected as well? I want to implement a co-simulation with patterns, thus bypassing the fscanf bug is more complicated.
Regards
Frank
Hi Frank,
We are looking into this but cannot guarantee a timeline. The behavior seems platform dependent.
Using fgets() with a custom parser should give you the flexibility you need to implement co-simulation with patterns. As far as I know the fstream functions refer to C++ which is not relevant here, but I’m not aware of other standard C functions which don’t behave as expected.
Best,
Bryan
