How to establish Xml-rpc interface to plecs from Octave instead of python?
User manual describes the steps for python as scripting language. When using python, I am unable to use matrix values for initialization using optStruct. This is because of python datatype conversion.
Rather than using the initialization commands in Plecs, I want to use Octave as scripting language to establish xml-rpc interface and initialize the matrix values obtained from Octave script to Plecs. .
I do not have any firsthand experience with this, but an initial search points to using the Apache XML-RPC libraries, similar to how XML-RPC is supported with Mathworks tools. A few resources I found are this website.
That being said, I’m not 100% confident this is the most straightforward path for you to achieving your goal of “initializing with matrix values”. You might be better off aligning your matrix with the convention used in the Python 3 script example below and attached case.
import xmlrpc.client
server = xmlrpc.client.ServerProxy("http://localhost:1080/RPC2")
opts = {'ModelVars':{'var':[[1,0],[0,1]]}}
server.plecs.simulate("matrix_xmlrpc",opts)
matrix_xmlrpc.plecs (5.29 KB)
