Inverter with constant DC source and AC current control.plecs (48.6 KB)
DC voltage VDC=800V
• AC RMS phase voltage VAC=230V
• AC current ripple peak to peak ΔI=2A
• Inductor internal resistance RL=0.036 ohm
• DC voltage ripple peak to peak ΔV=0.5V
• Rated power P=8kW
• Inverter switching frequency fSW=10kHz
according above data, the simulation and ac current controll is correct and wave form is correct. i need comment on that. if it is incorrect kindly correct me
This model has several fundamental issues in its implementation and the waveforms are likely not what you expect. As I suspect this is from a class assignment, I recommend discussing this with your instructors and colleagues.
