I’m using PLECS standalone and I want to use one script for setting parameters, and another script that calls first script and starts the simulation and does some other job. When I write the name of the first script in the second script I get an error like this: Error in script ‘set_parameters’, line1: ‘set_parameters’ undefined.
Are you using the inbuilt Simulation Scripts? You can call a .m file script from PLECS Standalone (Initialization Commands or Simulation Script) that contains your parameter definitions. Would that be suitable?
As Kris suggested you can call an *.m file from PLECS. The *.m files can be nested. Attached is a simple example.
The issue is that PLECS can’t seem to find the file you’re referencing. Are you calling “set_parameters” in the “set_parameters” script itself? Is it in a different folder or have a different name?
Personally, I think the run(“model_name.m”) syntax is a bit clearer since I know what’s a script and whats a variable, and you can reference scripts in sub-folders.
script_from_script.zip (2.81 KB)
One small note, the file-path syntax in the above model is OS dependent. The file runs as is in Windows, but for OSX/Linux should be configured as:
run("folder/setR2.m")
