Is it possible to change block parameter during simulation?
Hello all,
it might seem the usual question but it isn’t.
I have an ideal transformer and its parameters are written in the initialization commands.
I would like to change the number of turns during the simulation (like a tap changer) so I can change the value of the secondary voltage (or primary) and so the power.
I saw there are a lot of useful tips to change parameter during the simulation in the forum (1-D look table, step, ecc..) but I think that no one can be right for my purpose.
Any idea?
Thank you in advance!
Unfortunately it is not possible in PLECS to tune the parameters of a non-signal during a simulation. One idea though is that you could try and build a tap-changing transformer from primitives. You would need to use a multi-winding transformer, physical on-off switches, and switching logic to control the electric connections determining which windings are used at any given time (and therefore controlling the tap ratios). I would suggest using a lookup table to define the switch state logic and start with a simple example before scaling up.
Hi Kris!
Thank you for your answer!
Then I will try this way…
Best regards!
