currently I’m facing the problem that the RT Box is entering sometimes the error mode, when the connected controller resets. The model is an inverter where the two half-bridges are controlled using an external controller. The controller is placed on a custom extension board which just maps the signals of the RT Box to the corresponding pins of the controller.
The issue is that the RT Box randomly enters the error mode after a reset or even when the first time the controller starts to switch the half-bridges. At the moment I’m only able to reset the RT Box by rebuilding and uploading the current unchanged model. Which tooks quite a while, to speed up this process I’m searching for a method to reset the RT Box without building the model again and upload it.
Is there any methode built in the RT Box? Cause corresponding to the manual there seems to be none…
Valerian
