I know there is a PIL demo video available online with NPC-Solar inverter but I do have some questions:
is there any more detailed or simpler example available (i.e simple sine waveform/signal generation from MCU output to PLECS scope)? From the currently available source code for NPC-Solar inverter, it is difficult to parse what is needed and what isn’t.
Also, how does one use the PILPREPTOOL.exe?
do I run PILPREPTOOL.exe manually in the CCS workspace?
Where should I save the PILPREPTOOL.exe? I tried to build the source code in CCS, but it is prompting an error called “pil_symbols_c.inc” pil_symbols_c.c /npc-solar_28379 line 28 C/C++ Problem"
My pilpretool.exe is saved in path: C:\PIL\Tools\1.2\win32\pilpreptool.exe while the project is saved in path: C:\PIL\TI\C2000\5.1
pc-solar\28379
268 (724 KB)
I am currently using the TI F28379D launchpad.
Thank you for addressing these questions.
Jin G.
