I have a multilevel VSI based on NPC cell on which I perform losses studies.
With the library NPC block, I made my own NPC cell with the heatsinks in it :
I wanted to see if the losses were the same for every NPC cell in the multilevel converter (about 16 levels) so I copied my masked subsystem with the heatsinks in the entire converter.
Now my simulation is really slow du to all the thermal computations.
So, is there a way to switch off thermal computations for specific subsystems ? I tried to use the command plecs(‘set’, ‘componentPath’, ‘CommentStatus’, ‘CommentedOut’) on the heatsink in the masked subsystem initialization panel but plecs tell me that I can’t modify the circuit while the simulation is running.
Or do I have to manually comment out all the heatsinks ?
Thanks for your responses,
Paul
