Logging from RT BOX CE through TO FILE block
Greetings, I’m working with an RT BOX CE, and I would like to know if there is a way to write a file using the block TO FILE from the RT BOX library with a sampling time of the order of many seconds, e.g. 20 seconds while using an overall discretization step time of 20 microseconds or similar.
Yes - you need an USB stick with sufficient capacity and speed and version 2.2 or newer of the target support package. At 20 µs only MATLAB data (.mat) files can be generated.
Note that the number of signals that can be recorded is limited by the bandwidth of the USB port (480 MB/s) and the speed of the USB stick.
