Dear plexim Team
PFC_einphasig_bidgless_bipolar_APFC_Regelstrecke_bestimmen.plecs (26.1 KB)
In the attached model i want to measure the controled system with the help of an AC sweep. In comparsion to the buck converter example this model has a AC voltage source. When i try to measure the current response (iL) i get a unrealistic solution (amplitudes and phase response with many peaks). Is it possible to measure the controled system H(s) = iL/D like this? What do i have to adapt in my model that it will work?
Thank you for editing this post.
Raphael Baumeler
Hi Raphael,
Small signal analysis conceptually requires operating around a linearized operating point. That is not the case in your model. You are operating at a constant duty cycle while the AC grid voltage changes. If we think of the ~iL/~D of a buck converter, it depends on D’ or 1-Vin/Vout so there isn’t really one transfer function for this system as you’ve implemented it.
A common approach for analyzing PFCs would be choose a DC operating point on the AC curve for the controller design. Another approach would be to implement a controller and reformulate the perturbation such that the perturbation represents a “more linearized” system. Christopher Basso has good reference material on this topic.
Bryan
Hi Bryan,
Thanks for your reply. I understand that my model will not work. Can you show me how you would analyze this model with a DC operating point?
Where can i find the reference material from Christopher Basso? Do you have an example?
Thanks for your time and help.
Raphael
Hi Bryan,
Thanks for your reply. I’ve tried it with a DC Voltage Source and it works now.
Thanks for your help.
Raphael
Glad to hear you have things working. Regarding Basso’s work, I believe he had a recent tutorial at APEC on PFC simulation. He also has several books, but I’m not certain which one is most relevant to your immediate question.
