My PLECS RT Box is unable to connect to the computer via ethernet cable
This is not an appropriate question for the user forum, please contact support@plexim.com and provide more specific information on you issue.
Thank you,
following the RT-Box manual Page 8 “using static IP address”. (the file named “interfaces” without txt suffix)
using the ethernet cable connect one side to the rt box, the other side terminal NOT directly connect to your PC, but use a converter to connect to your PC via a USB I/O .
try it
Hi Yanshao,
Thank you for your answer. The ethernet cable from the RT Box can be connected directly to an ethernet port on your PC, provided there is one available. In case a port is unavailable, an adapter can be used.
For more questions on RT Box installation, please send an email to support@plexim.com. I can provide you with a step-by-step tutorial.
Manu
