I can get the target device through the Browse RT Boxes button, but I cannot load the web interface, no matter in my web browser or in the PLECS.
This is probably due to a wrong network configuration.
Please provide more information:
How is the RT Box connected to the PC, are they on a common network or is there a direct network connection to the PC?Are you using a DHCP server or did you configure a static IP for the RT Box? If static, which IP addresses are used by the PC and the RT Box?Can you start models on the RT-Box from PLECS?
Thank you for your answer, I have solved this problem by changing the IP addresses of my PC.
But it is weird that the IP addresses in the file /config/etc/network/interfaces from the SD card is, for example, 192.168.0.102, but in the “Internet Protocol Version 4 (TCP/IPv4) Properties” window, I have to enter 192.168.0.101 as the “IP address”.
Anyway, I can use the rt box web interface now, and thank you again.
In /config/etc/network/interfaces on the SD card you specify the IP address of the RT box. In the “Internet Protocol Version 4 (TCP/IPv4) Properties” window, you specify the IP address of your PC. This is how TCP/IP works. Each device must have a unique address.
