Scope Objects Disappearing when Switching between Mac and Windowss
This is a problem I’ve been having for awhile. I work on a .plecs file with my Mac and then when I want to work on the same .plecs file with a Windows PC the scopes disappear and I get a number of error messages upon opening the file with my windows PC. Some of the errors are the following:
Error applying parameter ‘TaskingMode’ in block main_file: Unknown parameter ‘TaskingMode’.
Error applying parameter ‘TaskConfigurations’ in block main_file: Unknown parameter ‘TaskConfigurations’.
Error applying parameter ‘ScriptsDialogGeometry’ in block main_file: Unknown parameter ‘ScriptsDialogGeometry’.
Error applying parameter ‘ScriptsDialogSplitterPos’ in block main_file: Unknown parameter ‘ScriptsDialogSplitterPos’.
Error applying parameter ‘DialogGeometry’ in component main_file/Sorting: Unknown parameter ‘DialogGeometry’.
Error applying parameter ‘ShowLegend’ in component : Unknown parameter ‘ShowLegend’.
C:…\main_file.plecs, line 1217: syntax error before 'ShowFourierLegend
Removing component Scope because of parse errors.
Is there something I should change in the settings to prevent this from occuring?
Thanks
This might be due to a PLECS version mismatch. Based on the error messages it looks like you are opening a PLECS 4.4 case in PLECS 4.3 or earlier.
Please ensure you have the latest, or at least compatible, versions of PLECS on both PC’s.
