Simulation ERROR: Could not solve the algebraic loop
I am trying to simulate a GSC based on simple 3 controlled voltage sources. Basically, I have implemented PQ-controller. When I try to simulate it produces an error;
At t=1.09623965334250585e-22: Could not solve the algebraic loop comprising the following components: 1: PI_PQCtrl_with_L_filter/Circuit1/3ph->SRF/alpha 2: PI_PQCtrl_with_L_filter/Circuit1/Sum2 3: PI_PQCtrl_with_L_filter/Circuit1/V8 4: PI_PQCtrl_with_L_filter/Circuit1/V7 5: PI_PQCtrl_with_L_filter/Circuit1/V6 6: PI_PQCtrl_with_L_filter/Circuit1/3ph Meter 7:
and so on…
I already tried to insert some delay element in the loop but it doesnt work. Could you please point out what are different solutions possible to this problem?
What should I need to change?
Attached the model
PI_PQCtrl_with_L_filter_controlled_voltage_source.slx (52.3 KB)
param_definition.m (407 Bytes)
The voltage input on the left hand side of your model is a linear function of a voltage measurement elsewhere in your circuit (i.e. linear relationship between “Vg_af” -> “Vg_nach” -> controlled voltage sources due to feedforward). The voltage measurement at that node directly depends on the voltage input and the voltage input depends on the measurement.
As you suggested, one effective solution is to insert a delay in your control loop along that signal chain previously referenced. One logical place would be just before your voltage source input on the left-hand side of your circuit that represents the modulator delay.
