Hello everyone,
I created a plecs model of rectifier with active and passive component and when I run it I get this error on the headline with :
Solver encountered an error while simulating model ‘name_plecs’ at time 0.10000000000000037 and cannot continue. Please check the model for errors.
Nonlinear iteration is not converging with step size reduced to hmin (3.552713678800501E-016) at time 0.1. Try reducing the minimum step size and/or relax the relative error tolerance.what this error means and how can find which component is causing this error?
Thank you
