Target response 99, Unknown error , First Time Build PLECS-RT Box
I am trying to build a simple model on the RT Box for the first time, but I am encountering the error “Target response 99”, which does not provide any detailed description.
I have verified that communication with the RT Box is working:
  • I can successfully ping the RT Box.
  • I can access the RT Box web interface using its IP address.
  • The PLECS RT Box target package version and coder target version now match. There was initially a version mismatch error, but that has been resolved.
I have not installed Zeroconf because I am communicating directly via the RT Box IP address rather than using the hostname.
Could the absence of Zeroconf still cause this issue, even though I can communicate with the RT Box successfully through its IP address?
I am attaching screenshot for same
Thanks & Regards
Sanket
This is probably not related to Zeroconf (although you seem to use self-assigned IP-addresses that may change after every boot. This is not a network setup that we support, you should use either static IP addresses or a DHCP server).
The error may be related to the location of your codegen directory, which seems to be on a network drive. This sometimes causes strange problems - try to use a local directory on your PC instead.
Thanks, After moving to local location the problem was resolved. I will also assign static IP instead of self assigned one.
The problem may be the path, which looks like there is something like a unicode “half space” or similar in “Ausbildung+ Studierende”. Non-ascii characters in file paths don’t work particularly well on Windows (but hey, it’s only 2026).
