Unstable 3 phase currents at speeds above 1000rpm
I have built a half bridge rectifier for a 3 phase PMSM. i am using hybrid switches in it and have set the appropriate turn on/off delay times for the hybrid switches. additionally i have also set a delay time so that the top and bottom row of switches in the rectifier are not activated at the same time and creating a short. at speeds up to 1000rpm i can see the 3 phase currents behaving as expected and am getting appropriate loss values for the switches. as i start to go above 1000rpm (with everything else fixed), the current waveforms get imbalanced and so does the speed and i get very high switch losses (in the range of 1e6). i have attached my model, is there a setup issue or am i missing something obvious?
HyS.plecs (258.7 KB)
You are re-using the controller design from a PLECS demo model. One difference in that example is that the machine has Ld=Lq and Ld is used in the plant model for controller tuning. In your model Ld = Lq / 3. If you set Ld=Lq then the oscillation goes away. You must adjust the controls design to better handle saliency, for example only Ld is used in the controller design and the feedforward term is only Ld and not Ld and Lq.
Also note that the machine is effectively in standstill and the speed you are measuring is actually the constant speed source.
thnk you both for the feedback.
i have addressed the speed i am recording, thanks for pointing that out.
i set the ld=lq and at higher speeds i am still seeing the same phenomenon (see images attached at 1000rpm and then at 10000rpm)
I removed the thermals in the attached model. It is working at 1.5 kRPM. You can use the PLECS Compare feature to differentiate the models. Oliver’s comment about the machine speed is critical.
HyS_BL.plecs (254.3 KB)
thanks Bryan
I ran the model you had attached, ait seems to manage until 7000rpm and then it falls apart again as soon as i put to 8000 rpm.
not disrespecting the changes you’ve made themselves, just trying to understand what is causing this?
Your PI controllers hit their anti-windup limits under those conditions.
thanks Bryan, managed to finally get it working
