Error wirting to file://…Verify you have access to that directory.
Hi Yu_Johanna_Cao,
It is not entirely clear what issue you are experiencing based on the information provided.
Could you please provide the following:
- A minimal example model that reproduces the issue.
- The version of PLECS you are using.
- A description of how the behavior differs from the previous version of PLECS, including which previous version you were using where the issue did not occur.
- If you are using the RT Box or one of the Target Support Packages (TI, ST, or XMC), please also provide the corresponding version numbers.
This information will help us better understand and reproduce the issue.
Dear Munadir Ahmed,
The version of PLECS you are using.A minimal example model that reproduces the issue.
I cannot open ver.5.0 PLECS although I have already download the same license in root catalog. -
I am using ver.4.7.5 now and it run well. -
A description of how the behavior differs from the previous version of PLECS, including which previous version you were using where the issue did not occur.A description of how the behavior differs from the previous version of PLECS, including which previous version you were using where the issue did not occur.
I cannot open ver.5.0 PLECS although I have already download the same license in root catalog.I am using ver.4.7.5 now and it run well.
Hi Yu_Johanna_Cao,
Please note that PLECS must be installed either for the current user or for all users of the machine. An installation for all users requires administrator privileges.
Also, the installer executable cannot be run from the root directory of a drive. Please move it to a subdirectory before running it.
Detailed installation instructions are available here:
