The transformation from alpha beta to dq doesnt output the correct results. I have compared it to matlab’s block then. It turns out that the blocks give erroneous results??
I have attached the simulink file through which I did my comparison. Could somebody clarify where is the mistake?
The SimScape transformation blocks have a “Rotating Frame Alignment” parameter. To compare the equations between PLECS and SimScape, the frame alignment must be set to “Aligned with phase A axis”. In that case the equations shown in the MathWorks help aligns with the PLECS component.The inputs into your PLECS Scope are switched.
